81 KZ750 LTD Bad Coil-Suggestions for Replacement?
- brox
22 May 2008 07:33
I finally figured out I have a bad coil. Any suggestions as to what I should replace it with? OEM or aftermarket? Thanks.
From Bismarck, ND
1981 KZ750 LTD w/Kerker Header
2006 KTM 200 XCW
2006 KTM 200 XCW
Re: 81 KZ750 LTD Bad Coil-Suggestions for Replacement?
22 May 2008 09:39 - 22 May 2008 09:44
Dyna from Z1E.
And if it's a four cylinder would replace both coils.
And also get new Dyna solid core plug wires which come with new caps already in place.
Good Luck!
Good Luck!
Last edit: 22 May 2008 09:44 by Patton.
- brox
22 May 2008 11:47
Do you suggest the Dyna Mini coils or the 3 Ohm green coils? Thanks.
From Bismarck, ND
2006 KTM 200 XCW
2006 KTM 200 XCW
22 May 2008 15:34
According to Z1E's listing, the Mini coils are not to be used with the Dyna-S electronic ignition.
I am very well-pleased with the 3 Ohm green coils and Dyna-S ignition (together with Dyna solid core plug wires, which come with caps already fitted), all from Z1E.
Good Luck!
Good Luck!
