Rubber pieces on lights for speedo and tach
- seanof30306
22 May 2008 05:27
I just got my speedo and tach back from Z-Resto, and they look awesome! Can't wait to get them back on the bike.
I noticed the rubber pieces around the instrument lights for the speedo and tach are worn out, and It doesn't look like they'll seal properly.
I called Z-1 Enterprises, but the parts are no longer made. I definitely don't want any moisture getting in to my newly-restored gauges.
What should I do?
What should I do?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- fordtruck
Re: Rubber pieces on lights for speedo and tach
22 May 2008 22:17
Mine were like that too when I changed the bulbs. I just wrapped the sockets in electrical tape until it fit snug into the housing.
'77 KZ1000-MTC 1075 kit. Stage 1 port
- Makarth
22 May 2008 22:43
use some dielectric grease it will repel water and help seal the little cracks. you can also try saving the grommets with some silicone oil. if nothing else buy a chunk of rubber and carve it until it fits. good luck.
- kenskz1000
23 May 2008 01:38
Try Redline cycle they have them.
