Trouble starting!
  • EasyRider1
  • EasyRider1's Avatar Topic Author
Trouble starting!
21 May 2008 13:39 - 21 May 2008 13:40
#214957
I have a 1981 kz440. Since it's warmed up my bike has actually gotten harder to start. Sometimes it will wear the battery down completly without starting. What could be going on here? I use the choke and that doesn't work. It sounds like it's going to start and then dies right after.
1978 KZ650C
Last edit: 21 May 2008 13:40 by EasyRider1.
  • EasyRider1
Re: Trouble starting!
21 May 2008 14:56
#214966
Alright, I think I got it all worked out. I was looking things over and noticed that one of the carb boots (that I bought only a few months ago) was cracked! This is VERY annoying, and if you've had to buy these before you know how expensive they are. Anyway, after cursing the aftermarket dealer/manufacturer of this product to myself, I applied some "plasti-dip" to the crack and that seemed to work for now. Also, tightened up a loose spark plug and charged the battery. She's good to go again! Thanks
1978 KZ650C
  • EasyRider1
23 May 2008 18:11
#215424
Well, the bike is still giving me the same starting problems even though I fixed the boot etc. Any advice?
1978 KZ650C
