no power to my starter ????
- triggerbilly
20 May 2008 21:10
I'm trying to get my 82 kz750-e back on the road (after twenty years)
the original owner took it off the road and garaged when someone cut his hiring harness up.
i've patched the harness back together (just a few things not working right but i'm getting there !!
when i press the start button I get nothing (not even a click) when i short the solenoid poles the starter turns.
Is it wiring or am i missing something obvious
(the starter button in switched to run)
any suggestions
or more simple wiring diagrams of the starting circuit
thanks
GT
any suggestions
thanks
GT
1982 kz750-e3
1983 cb1000c
plano. TX
1983 cb1000c
plano. TX
- 6leafclover
Re: no power to my starter ????
14 Aug 2008 09:33
I have the exact problem mine did it one day out of nowhere, the starter button wouldent work, not even a click but i too can jump the relay and it cranks.
1979 KZ1000-E1/ST
Madison, IN
Madison, IN
- OKC_Kent
14 Aug 2008 10:34
This bike probably has a lockout switch to the clutch lever. Are you pulling in the clutch when you try to start it in Neutral? If the switch is bad then pull the wires and connect them, see if it starts.
Or, you're not getting power to activate the solenoid from the wiring that is there now. You can get your meter or test light and check the circuit; start backwards from the starter solenoid until you get to a spot that has 12 volts. There could be a break or short from that point back to the solenoid. Make sure the solenoid is grounded too.
You will find a color wiring diagram for your model in the Filebase area of this website.
Good luck
Good luck
Cashion, OK
78 KZ650 B2 85,000+ miles
- Philip Meaney
14 Aug 2008 16:22
Or you could simply have a bad solenoid - if it's been sitting for years, it could be that simple. Have you tested the solenoid itself? Shorting across the poles takes the solenoid out of the equation.
80 750 H1
85 750 Turbo
84 GPz 750
85 750 Turbo
84 GPz 750
- MFolks
14 Aug 2008 18:48
I've mentioned on another website
www.kawasaki.org/forum
about replacing the $100 solenoid with a $15 from the riding lawn mower shops. Take the old solenoid with you and see if you can match one up.
With some slight wiring mod it will work as well as the factory one. One rider at the other site went to John Deere, and I understand Sears carries parts for their mowers also.
- wiredgeorge
15 Aug 2008 07:12
OK... first test the solenoid. With the solenoid in place and the battery connected, turn the key on. Take a wire you know is hot, like the RED brake running light and tough the little soldered contact where the black wire attaches. If the bike cranks, the solenoid is GOOD as it is shutting when a trigger voltage hits it. If the starter doesn't turn over, the solenoid is bad and needs to be replaced. I would find a used solenoid that has the same general configuration as the original for ease of mounting. Many Kaw and Suz solenoids share the same manufacturer and can be used. The Kaw solenoids will often have a BLACK hanging off them where an almost Suz solenoid will not. This black wire is just a ground that would be connected to the regulator or reg/rec and you can connect the needed ground to a frame ground.
OK... the solenoid is GOOD but still no click? Start troubleshooting. Get a multimeter and test the voltage (with key on) OUT of the kill switch where it goes to the start button. If you have voltage there with the kill switch in the run position, either the button is bad or the wiring to the solenoid. With power coming off the kill switch and the key on, push the start button and test for power at the major connector for the black wire coming off the starter button. Your bike DOES have a lockout loop. To do this test, pull the black wire out of the clutch interlock switch and stick a short piece of wire in both ends of the wires that went into the switch. This will hotwire the interlock during the test. If you have power at the connector on the frame neck but not after re-plugging in the interlock, the clutch switch is bad. If you find you have power with the interlock switch actuated and the button pushed at the connector, then the problem is with the wiring in the harness between the other side of the connector and the solenoid. You can test continuity by putting the meter in Ohms scale putting the probes on the solder joint on the solenoid and corresponding pin where the trigger voltage is conveyed inside the harness side connector.
