charging problem
- monsterman21
charging problem
18 May 2008 15:17
I have a charging problem with my 1980 kz650. What happens is it will only start with kick, the electric start will crank over once then give up, but when i ride it the battery doesnt drain or anything like that. The coils are fairly new from dyna and i have a dyna s in it too. I ordered a NOS stator for it, will this help recharge it? If not tell me what i should do.
Thanks
Thanks
Re: charging problem
18 May 2008 15:53
monsterman21 wrote:
Existing stator may be okay. Insufficient battery charging could result from faulty wiring or a loose connector somewhere. Maybe a faulty rectifier or voltage regulator. Could be simply a weak battery, or battery that needs charging overnight, or fluid level in battery is low, etc.
Would also check for good solid ground connection where negative cable from battery attaches to engine or frame.
Would first test charging rate. At 3-4000 rpm, the battery voltage measured across terminals should be 14-15 volts.
Good Luck!
Thanks
Good Luck!
- quader98
18 May 2008 15:56 - 18 May 2008 15:57
ya beat me to it,jus as i was typing
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
82 GPZ 750 R1
Last edit: 18 May 2008 15:57 by quader98.
- monsterman21
19 May 2008 03:21
Every time i hook it up to a charger it has full life and will start my bike up but after riding it and using it about 4 to 5 times it doesnt want to start anymore with electric
- BSKZ650
19 May 2008 11:03
have you put a meter on the battery while running to see if it is charging or not, that should be the first thing to check
77 ltd1000, current rider
76 kz900, just waiting
- Warthog
19 May 2008 14:09
BTW where do you buy a NOS stator from. I need one for a 1979 kz650.
This message brought to you by Hotdog
- Qdude
- It is all good.
20 May 2008 02:57
I think I would check the ground connections first.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- monsterman21
22 May 2008 03:20
Warthog wrote:
I found mine on ebay i got it for 212 dollars from kawasaki they are 411 dolars
- Saki Jockey
22 May 2008 17:05
Will it turn over if you jumper the solenoid? If so, its time for voltage drop checks. Follow the starter power circuit (heavy cable) to the starter motor with the positive lead of your multimeter during a start request. You'll need to investigate any drop of 1 Volt or more.
Rob A.
550 A4
GTA,
Ontario, Canada
550 A4
GTA,
Ontario, Canada
- kawsakiman
22 May 2008 17:47
monsterman21 wrote:
holy crap!
$200?
want to buy a couple more?
used but work great, i'll sell them for half that.
i would also check the + cable
or maybe you just have a bad starter drawing to many amps.
the brushes do wear out over so many years.
Warthog wrote:BTW where do you buy a NOS stator from. I need one for a 1979 kz650.
holy crap!
$200?
