red, orange & brown wires ? 76 KZ900
  • woodyskz
  • woodyskz's Avatar Topic Author
18 May 2008 10:52
#214350
where does the orange wire with the spade connector that is near the battery box go to? It is run with a red and a brown wire that are loose also. Location.. right side, front of Battery box tied onto the frame. Thanks .
  • PLUMMEN
  • PLUMMEN's Avatar
Re: red, orange & brown wires ? 76 KZ900
18 May 2008 18:24
#214444
turn signal relay?:blink:
  • Old Man Rock
  • Old Man Rock's Avatar
20 May 2008 07:09
#214713
Might be your hazard terminations.
I also included the KZ900 4/5 wiring diagram.
members.cox.net/ruinsofstei/z900A4+5%20wiring%20diagram.pdf
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • woodyskz
20 May 2008 17:32
#214824
Yep, hazard relay is missing. I'll see if Jeff's got one on hand. Thanks for the help.
