Voltage drop?
- snapdaddy
Voltage drop?
13 May 2008 07:18
I'm helping my brother troubleshoot a no spark condition on his 76 KZ900 with Dyna ignition...what we're up against is a strange drop in voltage when the ignition switch (key) is turned on. The main white wire coming from the fuse box to the ignition switch reads 12.27 volts (same as the battery) with the key off...turn it to 'on', and it drops to 10 volts. Reading at the yellow/red wires on the coils is 9.1 volts. The kill switch was bypassed by a PO, so that's not the problem. Thought I'd turn to the gurus for some direction! Thanks
\\\\\\\'76 KZ900 - 1015cc
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: Voltage drop?
13 May 2008 08:55
Your problem is pretty typical of these old bikes. Your answer to how to correct your drop in coil voltage can be found at
www.wgcarbs.com/index.php?option=com_con...view&id=12&Itemid=26
Many of us here have done this with good results. Anymore I just do it as a routine thing when I get a new old bike.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- snapdaddy
Re: Voltage drop?
14 May 2008 08:59
Thanks, that looks like a nice mod. However, the drop we're seeing wasn't there last year and is keeping the bike from starting at all. Tonight we'll read resistance across all the handlebar switches - with those switches unplugged, we have no voltage drop. Fingers crossed!
- loudhvx
Re: Voltage drop?
14 May 2008 09:47
snapdaddy wrote:
The resistance is very low and difficult to read on bad conections. The problem doesn't usually show up until there is a large current flowing in the connection. The best way is to turn on the power and measure voltage drops across the suspect connections.
The dyna S uses about double the current of the stock system, and even more if you are using lower-resistance coils. Everything must be squeaky clean and solid when using the Dyna S. Any burnt or weak-looking wire in the path to and from the coils should be fixed or replaced.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
