Wiring harness
- swani
Wiring harness
07 May 2008 08:29
I have an 83 LTD 550 that has alot of electical problems so I purchased a wiring harness to try and remedy problem. Does anyone know where I can get a wiring diagram? I consider myself a decent mechanic but I have never done a complete rewiring, any pointers?
- JohNLA
Re: Wiring harness
07 May 2008 10:53
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
- loudhvx
Re: Wiring harness
07 May 2008 11:02 - 07 May 2008 11:09
For some reason John's link didn't work for me. Let's see if mine works.
home.comcast.net/~loudgpz/KZ5mnl.pdf
Well it didn't. Let's try it another way using the URL tags.
And this one is a color diagram for an 81, found here on KZrider. It's the first pdf.
diagram
diagram
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 07 May 2008 11:09 by loudhvx.
- tjhiggin
Re: Wiring harness
07 May 2008 14:40
I put a new wiring harness into my CB550 last year. It was a lot easier than I expected. I almost didn't need the wiring diagram. Just take it slow and do a section at a time; rear end, then under the seat, then under the tank, etc. Remove a wire from the old harness, connect it to the correct place on the new harness, then go to the next wire. By following this procedure I had almost no problems when complete. My electrical problems were solved and the old girl fired right up. Good luck.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
