Self-cancelling blinkers and headlight on/off switch
- seanof30306
30 Apr 2008 00:01
79 KZ650 B3
2.5 questions
1) What is the best (simplest/cheapest) way to swap over to self-cancelling blinkers. Are there handlebar switchsets from other models that swap over easily? Is there a kit to upgrade what I have?
2) My right-side handlebar switches do not have an on/off switch for the lights. What year models did, and will it swap directly over?
2.5) I need to wire the on/off switch for the headlights so they only turn off the headlight not the taillight. What's the best way to accomplish this?
2.5 questions
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- Qdude
- It is all good.
Re: Self-cancelling blinkers and headlight on/off switch
30 Apr 2008 01:57
There will be wiring diagrams in the filebase section here on the homepage.
With a little study, you can decipher the switch diagrams on the margins of the schematics.
My 77 has the headlamp switch, but Kawis dont have the cancelling blinker switch....
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- seanof30306
30 Apr 2008 02:45
Qdude wrote:
Thanks for responding.
I knew Kaws didn't have cancelling blinkers; I was wondering if handlebar switches from another make/model could be adapted and, if so, which might be the simplest.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- steell
30 Apr 2008 04:42
KZ440 had self canceling turn signals, don't know about any others.
On the 750 twins, Kawasaki did away with the light on/off switch for 79, so I used the right hand switch pod off a 78 to get it back. The wiring harness under the tank had a jumper connecting the wires formerly used for the light switch, unplugged the jumper and plugged in the wires from the 76 switch pod and it worked.
- seanof30306
30 Apr 2008 05:09
steell wrote:
That is great to know. You wouldn't know which years did/didn't would you?
Also, is there anything more to it than getting the handlebar controls and wiring them up?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- seanof30306
30 Apr 2008 05:46
Hmmmm ..... apparently, these are the models that had self-cancelling turn signals:
KZ440-A1 A2 A3 A4 D1 D2 D3 D4 D5
KZ550-C1 C2 C3 C4 F1 F2 M1
KZ750-H1 H2 H3 H4 K1 K2 H1 H2
They all used a self-cancelling turn signal switch, PN 27010-1077
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- Sandy
- Fly High,Tony
30 Apr 2008 07:50
I grabbed one of these from Jeff @ Z1.
With some rewiring(under the tank area)it works like a charm.
Now I can turn the headlight off (for testing purposes,working on the bike),without having to pull the fuse.
www.z1enterprises.com/detail.aspx?ID=2040
1977 KZ1000 A-1
- tjhiggin
30 Apr 2008 08:22
My '83 1100 has self-cancelling blinkers.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
- bountyhunter
30 Apr 2008 15:33 - 30 Apr 2008 15:34
"self cancelling" blinkers on a bike are usually implemented elctronically by using a 555 timer set up as a "power source" that will provide the +12V to the blinkers for a set time period after you turn the switch on, and then cut off. You have to turn the switch off and then back on and it resets and works again. It's fairly easy to implement if you are electronically oriented.
I just put a beeper on mine to remind me to turn them off.
Last edit: 30 Apr 2008 15:34 by bountyhunter.
- seanof30306
30 Apr 2008 16:49 - 30 Apr 2008 18:01
bountyhunter wrote:
Hehehe, those would appear to be the operative words.
bountyhunter wrote:
I just put a beeper on mine to remind me to turn them off. [/quote]
That is a great, simple solution that hadn't even occurred to me.
Can you tell me what buzzer you used, and how you wired it up? It'll probably be over my head, but I have a buddy who is much more electronically oriented than I am.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 30 Apr 2008 18:01 by seanof30306.
- bountyhunter
30 Apr 2008 18:55
Can you tell me what buzzer you used, and how you wired it up? It'll probably be over my head, but I have a buddy who is much more electronically oriented than I am.[/quote]
I bought whatever little 12V buzzer they had at radio Shack, and used some double sided foam sticky tape to stick it on top of the steerin g stem.
Wiring is pretty easy: you need two diodes like 1N4001 (Radio Shack or FRY's will have them). Hook the anode (positive end) of each diode to the +12V hot wire that connects to each of the front turn signal light. Tie both cathode (negative) ends of the diodes together and use that point to go to the + lead of the 12V buzzer. Ground the other side of the buzzer.
On mine, the front turn signal wires are inside the headlight cowl so it's pretty easy to get at the wires.
bountyhunter wrote:"self cancelling" blinkers on a bike are usually implemented elctronically by using a 555 timer set up as a "power source" that will provide the +12V to the blinkers for a set time period after you turn the switch on, and then cut off. You have to turn the switch off and then back on and it resets and works again. It's fairly easy to implement if you are electronically oriented.
- Limey
- 3 Years in the U.K. - Brought the KZ with me!
01 May 2008 06:33
A beeper, or a simple timer are pretty easy to do. I'm not sure how the factory "self cancelling" system works on a KZ, but on a Yamaha it is a combination of speed, time and distance! If the bike is moving over a certain speed, the signals stay on for a set time, below that speed, a set distance. That way, they don't time-out if the bike is stationary!
A system that works that way requires a bit more electronics - and logic! However, you could do it with a "Basic Stamp" and a GPS module!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
1978 KZ650
2000 ZG1000
