81 kz550 wont start ..new to KZs...HELP!
- nfester
29 Apr 2008 15:33
ok so long story short i acquired an 81 kz550 through a family member, it wont start, if it wont crank how do i check if its getting spark ... or what do i do... im new to motorcycles so any advice will be greatly appreciated.
- bountyhunter
Re: 81 kz550 wont start ..new to KZs...HELP!
29 Apr 2008 16:15
Charge the battery. Get a volt meter and measure the battery voltage as you try to crank the starter. If it cranks over, use a timing light to see if there is spark on the plug leads. make sure the tank has clean gas in it.
- Qdude
- It is all good.
29 Apr 2008 20:04
Spark can also be checked by removing a spark-plug and placing it on the head, while it is plugged in to a live plug wire. Once again, be sure that it is grounded to the head and plugged in in a way that you can see the electrodes.
Crank the motor over and watch the plug for spark between the electrodes.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
