battery wont stay charged
  • njk031
  • njk031's Avatar Topic Author
26 Apr 2008 18:12
#209332
I have a brand new battery, charged correctly. I have a 1981 kz1100. Does it have an alternator? Im not very experienced with the mechanics of the bike. Maybe its a fuse that is blown? The battery wont stay charged after several starts.
  • bountyhunter
  • bountyhunter's Avatar
Re: battery wont stay charged
27 Apr 2008 21:24
#209671
It has an alternator that puts out 3-phase AC voltage and feeds to a rectfier bridge to convert it to DC. There is a solid-state regulator that adjusts the ON time of the rectifiers to hold the system voltage at 14V and keep the battery charged.
If the battery isn't charging, it could be the alternator, rectifier, regulator or associated connections. You need a manual with a wiring diagram,
  • donthekawguy
  • donthekawguy's Avatar
28 Apr 2008 05:14
#209710
You need to buy or find a meter and a manual. On the older kz's you fire it up set the rpms to 3500 (if I remember right) and check the voltage at the battery. It should read 14 to 16 (again I think). Check all of the grounds and connections. If all connections are good check the regulator first. It might have a different set up being that it is an 81, but it's all kinda the same.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • bountyhunter
28 Apr 2008 09:46
#209784
If it's like most, there is no fuse between the output of the alternator/regulator and the + battery terminal. The fuses are all in the load lines to the various lights and accessories.
  • Qdude
  • Qdude's Avatar
  • It is all good.
29 Apr 2008 22:50
#210210
I would so check the connections and grounds first.
77 KZ 650 C1.
77 KZ 650 C1.
  • njk031
30 Apr 2008 12:57
#210327
thanks for all the advice. Does anyone know where I can get a diagram of the bike and its components. I dont even know where the regulator or the alternator are located.
  • tjhiggin
  • tjhiggin's Avatar
30 Apr 2008 13:28
#210329
You need a shop manual. Here's one on ebay.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
