turn signal ground?
  • squints
  • squints's Avatar Topic Author
turn signal ground?
25 Apr 2008 15:37
#209081
At the end of last season I changed bars on the kz1000 CSR to superbike ones and as a result there was no room for turn signals. They were the kind that mounted onto the handlebars - pretty sweet, sad to see them go.
I now have the right stems to attach the original signals to the headlight. BUT, when dismantling the old signals I found a black wire (I think for grounding purposes)that was screwed into the old signal stem/clamp. I checked out the wiring diagram which didnt offer any help...
SOO, If I put on the old lights and hookup the gray and blue wire but without this black wire will s*it hit the fan? Or should I fangle away to affix the black wires end to somewhere else?
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: turn signal ground?
25 Apr 2008 15:48
#209088
Yep, the black is the ground. You'll need to ground them somehow.
The wiring harness is grounded to the frame, and as far as I know, your bike should have ground lines fed into the headlight shell that you can ground to... whatever way you do it, you have to do it...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • RonKZ650
  • RonKZ650's Avatar
25 Apr 2008 16:06
#209096
You'll have a ground wire on the headlight bulb itself. You can tie into that or possibly if you're lucky they may have extra ground wiring right in the headlight shell waiting to be used.
  • squints
25 Apr 2008 16:12
#209097
ok, i'll find someplace to attach them. And Yeah there is a connection inside the headlight bucket. But what is it Im grounding exactly?? this electrical stuff sometimes boggels me..
thanks
Upstate NY
  • JMKZHI
  • JMKZHI's Avatar
Re: .
26 Apr 2008 11:46 - 04 Dec 2008 06:05
#209257
del
Last edit: 04 Dec 2008 06:05 by JMKZHI.
