Pic Request - Wiring under Tank
  • HerrDeacon
  • HerrDeacon's Avatar Topic Author
23 Apr 2008 02:59
#208388
I'm trying to clean up the 30 year old wiring mess from the PO and I'm having issues with the big group of wires running under the tank. Does anyone have a pic of the route that they should be taking? Do they go under the coils? Above? etc.
I tried a few different ways but the tank still won't go on correctly, its up on the left side.
Any help would be appreciated.
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Pic Request - Wiring under Tank
23 Apr 2008 05:56
#208405
Are you talking about the main bundle of wires that goes into the headlight? Like this?
  • HerrDeacon
23 Apr 2008 06:43
#208414
Yes, that's the one. Perfect pic, thanks a lot. Really appreciate it.
The PO has it different in that it doesn't go in between the tubes under the tank. I'll have to figure something out.
  • bill_wilcox100
  • bill_wilcox100's Avatar
23 Apr 2008 17:58 - 23 Apr 2008 18:02
#208562
As you can see from Bluemeanie's pic, the OEM cable came with a combination of rubber boots/tubes and or taped protection around harness.
I was accessing my harness often because of electrical problems and the taping and untaping was becomeing a drag. So, I went for a flexible plastic protector closed with a few black tie-wraps and secured with a few more black tie-wraps. It comes in avariety of sizes and is cheap at my local Canadian Tire.
I was just working under the tank so this is what mine looks like today.
Let's try the pics again.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 23 Apr 2008 18:02 by bill_wilcox100.
  • bill_wilcox100
23 Apr 2008 20:04 - 23 Apr 2008 20:10
#208592
Left side:
Upgrades:
Montreal, Canada
Last edit: 23 Apr 2008 20:10 by bill_wilcox100.
  • bill_wilcox100
23 Apr 2008 20:11 - 24 Apr 2008 05:08
#208595
Left side... sorry, the other left side:
Hope this is useful. Best of success. :)
Upgrades:
Montreal, Canada
Last edit: 24 Apr 2008 05:08 by bill_wilcox100.
  • Six9GS
  • Six9GS's Avatar
23 Apr 2008 20:30
#208606
On my 78 KZ650, One of the wire bundles runs on the left side and the other runs on the right side. Both route underneath the tank mount tang thingies. Don't know if that is the stock manner of routing them. However, I do not have any problems with the routing of these two bundles the way they are.
Terry!
  • bill_wilcox100
23 Apr 2008 20:43
#208614
Good stuff Six9GS! If it aint broken, don't fix it. ;)
Upgrades:
Montreal, Canada
  • HerrDeacon
24 Apr 2008 02:48 - 24 Apr 2008 02:49
#208657
Thanks guys, even though I would like to run it like Blue has it in his pic, the PO must have done some work there and now it routes below the frame tubes. I'm not diving into that mess of wires so I'll have to see how I can best route them the way they are. I'll look into that protector you mentioned Bill, looks neat.
Thanks
Last edit: 24 Apr 2008 02:49 by HerrDeacon.
