KZ1000 engine help
- snerff
KZ1000 engine help
20 Apr 2008 01:49
Hi all. I am new here. I was given what I think is a 1979 KZ1000 engine. I am having a hard time finding the engine numbers so I can track down the year. It is going into a "GOkart" I did not want to go too far with the build till I can get a wiring diagram and get it running.
I have enclosed a picture of my last project and now want to go all out with something new. Thanks for your help in advance.
- PLUMMEN
Re: KZ1000 engine help
20 Apr 2008 09:35
biggest wiring differance is going to be the charging system.look at the dyno cover if it is finned with kawasaki stamped in it chances are its newer style 79 -80,also look at the head if its got smog ports cast into valve cover its probably newer 79-80 atleast.if it has 1015 cast into front botem corner of cylinder its -80 if it has 998 its 81 or newer j motor.what are the numbers on cases above clutch cover?
- Sandy
- Fly High,Tony
