Headlight re fit
- robhavens
Headlight re fit
18 Apr 2008 20:46
Can anyone tell me if I would be able to use this light in place of the stock. It says that it is brighter than stock, but with same amount of power draw?
Hella Premium Plus 50% Xenon Boosted Halogen Headlight Bulb-H4, 60/55W
1978 KZ650 B2
1978 KZ650 B2
- The Milkman
Re: Headlight re fit
19 Apr 2008 05:33 - 19 Apr 2008 05:34
I can't really tell by your question, what bulb you are talking about. Sounds like
this one
though.
If you still have the stock style sealed beam headlamp, you will have to get a conversion kit like one of these.
Then you can replace the halegon with the one you are asking about.
I have found that the halogen gives off plenty of light though.
Ride safe.
Ride safe.
Last edit: 19 Apr 2008 05:34 by The Milkman.
- robhavens
19 Apr 2008 16:03
I have a vetter windjammer SS fairing, and it is a 7" headlight. I put a halogen bulb in not too long ago, but It is just not bright enough. I will get it out to take a look at the wattage. Do you know if there is a 7" fit for this light?
- The Milkman
19 Apr 2008 17:25 - 19 Apr 2008 17:28
if you click on the second link I gave you there is a 7 inch halogen conversion at the bottom of the page. It is a headlight that takes a seperate H4 bulb which is included. The first link is for a Xenon Boosted Halogen that will fit into that coversion housing.
All H4 bulbs are the same size and mounting system the only difference will be the bulb itself.
if you already have the h4 coversion you just need the h4 Xenon Boosted Halogen bulb.
Last edit: 19 Apr 2008 17:28 by The Milkman.
