KZ1300 Ignition Coils
- BLSSeattle
15 Apr 2008 22:16
Hi all. I need to get hold of 3 coils for my 79 KZ1300. I fould some that say they're for 2-cylinder models, and I found them via a search for my model. My stock coils drive 2 cylinders each. Toyo Denso's. Can I use the coils that drive the 2 cylinder engines? I'm new to KZ's. Thanks for any help.
- Iceman Too
- Even the finest shoe makes a poor hat
Re: KZ1300 Ignition Coils
16 Apr 2008 02:08 - 20 Apr 2008 11:00
Ah! KZ1300 coils. A lot of 1300 owners switch to hotter coils with higher output voltages and hotter spark. A few options would be Accel or Nology coils
accel.zn1300.com/
A cheaper option could be
www.kz1300.com/techarticles/z1300-gm-coil-swap.html
using GM or Chrysler coils. A search of Ebay using "KZ1300 coils" gives this result
search.ebay.com/search/search.dll?from=R...300+coils&category0=
which give you (scroll down) all of the above options along with 1 used OEM coil or a set of 3 used OEM coils. Remember that input coil resistance should be 2.5 ohms and some options may necessitate removing your inline resistor from the coil circuit. Good luck and good riding!! Lucky 13
1979 KZ 1300 (Under Repair)
1999 V-Max (Gonna ride it till the Kow comes home)Sold Kow came home
1980 KZ1300 B2 Touring
Nova Scotia
Nova Scotia
Last edit: 20 Apr 2008 11:00 by Iceman Too.
