LED blinkers
- baldy110
LED blinkers
15 Apr 2008 19:55
OK, I hope you electrical gurus can help me here. I swapped my conventional turn signals for LED's on my KZ650. Now they don't blink. Every once in a while they will flash once and stop. I swapped out the relay for a modern electronic one but no difference. The conventional ones worked prior to the swap. Any suggestions
- MCH650SR
Re: LED blinkers
16 Apr 2008 09:19
I know on the regular systems, there has has to be enough resistance in order to activate the flashing unit. I once tried some other flasher lights that had a 3W bulb. Did not work. Put in the regular bulb (10W?) it worked.
So I assume you would need a flasher unit that will work with the low wattages of LED lights.
just my experience
just my experience
1979 KZ650SR
modified with BS32 carbs
Yoshimura 4 in1
2006 Kawasaki Sherpa
1979 Honda CX500
BC Canada
Yoshimura 4 in1
1979 Honda CX500
BC Canada
- bountyhunter
Re: LED blinkers
16 Apr 2008 10:11
LED turn sgnals only work with a solid state flasher because they don't pull enough current to make a bi-metallic flasher open and close. I posted a schematic of one a while back. many places sell them.
- Biquetoast
- King Jeremy The Wicked
Re: LED blinkers
16 Apr 2008 16:41
baldy110 wrote:
The new "electronic" flasher required more power than my low battery had to open and close its relay. I never notice bad batteries because I always kick start. Now, when my blinkers stop working, I know my battery is low on fluid.... really low...
The exact same thing happened to me way back when I made the switch. For me, believe it or not, the fix was to top off the fluid in my battery.OK, I hope you electrical gurus can help me here. I swapped my conventional turn signals for LED's on my KZ650. Now they don't blink. Every once in a while they will flash once and stop. I swapped out the relay for a modern electronic one but no difference. The conventional ones worked prior to the swap. Any suggestions
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- baldy110
Re: LED blinkers
18 Apr 2008 19:41
OK I found the problem. Apparently the electronic relay can be wired incorrectly, as I found out, yeah I know how do you screw up two wires. On the old relay it did not make a difference which wire went to which terminal. Well the electronic one is not so forgiving. I swapped the wires and now it works great.
