Pic Request - Inside of Left Hand Control (KZ650)
  • HerrDeacon
  • HerrDeacon's Avatar Topic Author
15 Apr 2008 15:48
#206729
I'm trying to get all the little switches and circuit boards back in the left hand control of my KZ650 and I'm having a hard time figuring it out. I have the top half of the control done but the bottom is killing me. Basically I know where everything is supposed to go but I'm having a hard time getting it all in there correctly.
Specifically I can't get the hazard switch circuit board and the turn signal switch box to fit in at the same time. I'm obviosly doing something wrong.
I'm really hoping someone has a pic of the top half of the left control showing how the boards and switches are mounted.
Thanks
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Pic Request - Inside of Left Hand Control (KZ650)
15 Apr 2008 18:03
#206767
I had a look at a spare one I have. It's a little rusty and soaking with WD40. I couldn't get any screws loose at the moment.
Here's a pic:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • HerrDeacon
16 Apr 2008 02:49
#206826
Thanks rstnick. The problem I'm having it that the hazard wiring board is underneath the indicator switch and I'm having a hard time fitting it in and determining how the wires come out from underneath it. Can't really determine if from this pic, but it definitely tells me I was trying to do it the wrong way.
Thanks for posting the pic.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
16 Apr 2008 06:29
#206845
I'll see if I can take the indicator switch lever off later today. The screw is stuck at the moment.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • HerrDeacon
16 Apr 2008 08:34
#206867
Thanks rstnick, I'd appreciate it, but please don't worry if you can't get it off. I don't want you to strip or break the screw.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
16 Apr 2008 17:27
#206989
Well got some more apart:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
16 Apr 2008 17:29
#206990
That light blue/grey wire under the screw top right is not stock. It's a ground wire added after the fact:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • HerrDeacon
16 Apr 2008 18:08 - 16 Apr 2008 18:11
#206996
rstnick I owe you BIG time, you're a life saver.
That pic shows me what an idiot I am. When I disassembled the control one of the wires on the hazard board was broke loose so I soldered it back on (this was months ago). Problem is that I must have swivelled the wires around so I could access it a bit better. When I went to reassemble it I never swivelled them around again and so nothing seemed to fit. It seemed like the three wires had to go up behind the indicator switch housing! I completely forgot the wires can move around while still on the board.
I really appreciate the time you took to take those pictures for me.
Thanks again!
Last edit: 16 Apr 2008 18:11 by HerrDeacon.
