'78 KZ650 D1 - Couple of wiring questions
  • HerrDeacon
  • HerrDeacon's Avatar Topic Author
15 Apr 2008 08:36
#206654
I'm currently in the process of putting my bike back together and I'm working on the wiring. So far I've come across two issues where I'm a bit lost. I marked (or thought I did) all the wires during the tear down but there seems to be a couple that were not marked.
Firstly, the two black wires coming from the switch located in the clutch lever (is this the starter lockout switch?), I have one connected but I'm not sure where the other one goes. I'm assuming this connects to the black wire coming form the starter button on the right hand control? Seeing how you need the clutch in before the bike will start with the electric start, is this correct?
Secondly, the two wires going to the front brake pressure sensor located on the splitter, does it matter which wire goes on each pole or are they interchangeable?
I don't have any pics on hand but if they would help please let me know.
Thanks
  • mariozappa
  • mariozappa's Avatar
Re: '78 KZ650 D1 - Couple of wiring questions
15 Apr 2008 09:31
#206662
Yes, the starter lock out switch connects to the black wire going to the starter switch and the other connects to the black wire going to the starter relay.
AFAIK, the wire going to the front brake sensor are interchanable, but I am not certain.
There is a wiring diagram in the filebase for your bike.
78 650 D1
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • HerrDeacon
15 Apr 2008 14:13
#206716
Thank you very much for your help mariozappa, really appreciate it.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
15 Apr 2008 14:39
#206722
On my C model, one of the clutch lockout wire's plugs is male and the other female. They connect to the main harness under the gas tank in the same area.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Bluemeanie
  • Bluemeanie's Avatar
15 Apr 2008 19:17
#206782
Does this help?
  • PLUMMEN
  • PLUMMEN's Avatar
15 Apr 2008 19:35
#206790
Thanks
brake light switch can be wired either way;)
  • HerrDeacon
16 Apr 2008 02:44
#206825
Thanks guys. I had the wiring diagram but it never really told if the brake light switch had to connected a certain way.
Thanks again this is a great help.
