Spark plug wire replacement
  • Saki Jockey
  • Saki Jockey's Avatar Topic Author
13 Apr 2008 20:03 - 13 Apr 2008 20:07
#206258
After finishing up the WG coil mod and swapping plugs to D8EA from DR8EA, I'd like to change the old and tired plug wires on my 83 550A4.
The wires I have now I believe are copper core. I have been looking for copper core wire in bulk all winter without success, all I came across is distrubuted resistance wire. Does anyone know where (Aside from Z1E - Nothing against Jeff, but an order for $20 isn't worth his or my time and hassle - duty fees etc. ) in Canada I can find either bulk 7mm copper wire or a reasonably priced set of copper core wires with 90 or 135 degree boots? Canadian Tire has 'powersport' NGK cables, but at $20 a piece!
Rob A.
550 A4
GTA,
Ontario, Canada
Last edit: 13 Apr 2008 20:07 by Saki Jockey.
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: Spark plug wire replacement
13 Apr 2008 21:52
#206278
Sorry, I got mine from Jeff at Z1, rolled in with some other stuff I needed.
They came with ends and soft flexible boots. Boots not very pretty but OK.
Anybody else have a Canadian lead for Saki Jockey. :unsure:
Other than that you could try e-Bay. Best of success. :)
PS
Add your year, model and location to your signature. It gets the best responses and is considered very friendly.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
