WG coil mod results
- fordtruck
WG coil mod results
13 Apr 2008 16:11
I've been battling sooty sparkplugs for awhile now in my 77 KZ1000. I even rebuilt my carbs thinking that would help. It didn't. I finally checked my voltage to my coils. Wow! I have 12V at the battery and 9.9V at the coils. After doing wiredgeorge's coil mod, I have less than .4V drop at the coils. As a bonus, I found where the kill switch had been bypassed. I hooked it back up and it works fine. When the rain stops I will try it out and see if my sparkplugs improve. It sure can't be any worse!
'77 KZ1000-MTC 1075 kit. Stage 1 port
- Becker
- The Doctor Will Rise Again
Re: WG coil mod results
13 Apr 2008 23:23
I had about the same voltage at my coils as you did before I did the coil power mod. Since then I replaced the coil (turns out the insulation was fried) and also did the HEI mod that is on the WG website. You should se the spark I'm getting now. Before it was just a week blue line from the electrode to the ground but now its like a small bluish white ball exploding off the electrode. Much easier to start, and better MPG too.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
