replacement plug wires
  • killcity
  • killcity's Avatar Topic Author
11 Apr 2008 08:10 - 11 Apr 2008 08:24
#205693
can anyone recommend some decent plug wires to replace the aged ones on my '80 750h? maybe dyna? rode to work today and saw an arc dumping out of one of the plug caps. also, this is a new bike to me, but is replacing them a pain? i figure it should be pretty simple.
thanks!
Last edit: 11 Apr 2008 08:24 by killcity.
  • steell
  • steell's Avatar
Re: replacement plug wires
11 Apr 2008 09:13
#205711
Pick up NGK spark plug caps at any bike shop ($5-$7 each), and spark plug wires at your local auto parts store. Just get a set of "cut to fit" plug wires for just about any four cylinder car.
  • killcity
11 Apr 2008 09:25
#205714
cool, thats what i used to do...guess i have my weekend project lined up :)
thanks steell
-bj
11 Apr 2008 09:39
#205719
As another option, there's a good selection of Dyna plug wires from Z1E, with caps already fitted. :)
Z1E Dyna Plug Wires
  • killcity
11 Apr 2008 10:33
#205743
saw those. might do that too (seems a little cleaner)
  • billz
  • billz's Avatar
11 Apr 2008 12:00
#205766
Replacement wires will only work on non-oem coils. I know on the 900/1000s the wires are not removable from the coil. Check your coil before buying wires.
Bill
11 Apr 2008 15:45
#205811
For possible consideration, if needed --
Z1E's Plug Wire SPLICER
Good Luck! :)
  • steell
  • steell's Avatar
11 Apr 2008 18:43
#205827
Before I posted I looked at the coils on my 80 750E to see if they were the replaceable type, and the are. Might not be the stock coils though, never had another KZ750 four to compare.
