Ignition or carb?
  • Tere
  • Tere's Avatar Topic Author
Ignition or carb?
09 Apr 2008 06:34
#205169
After winter ltd440(82) carb cleaning, riding throttle up one cylinder didnt run.I think its ignition cause if I use, replacing new ngk, diferent spark plugs, side of runing cylinder changes.What can it be wires,coil?Is it posible that ignition damages without riding?Sorry for my english:)
  • Tere
Re: Ignition or carb?
09 Apr 2008 11:01
#205215
Just from garage, cleared that its charging, that is why spark is too weak for both cylinders when battery goes out.Is there some way to find out which detail is over,or wires, and is it possible to buy 82 ltd440 charging elements if I am in europe?
  • OKC_Kent
  • OKC_Kent's Avatar
09 Apr 2008 11:05
#205216
If you switch spark plugs and the other side runs, then the spark plug is bad.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • ronjones
  • ronjones's Avatar
09 Apr 2008 11:24 - 09 Apr 2008 11:26
#205221
Hi Tere, Nothing against any of the advice you are recieving here, but there is a very good group just for the KZtwins, specializing in the 440 and 400. You might want to check them out. The membership has many Europeans, a member might be close, to help out or to find parts.
kz400.com/
Last edit: 09 Apr 2008 11:26 by ronjones.
  • Tere
11 Apr 2008 13:21
#205783
Yeah got useful information about electricks,realy tricks.Just keep listening Jesu Lifeline and not roaring of my old school bike.Soon I'll bee wind for my quet town.
