buzzer (turn signal)
Re: buzzer (turn signal)
09 Apr 2008 21:01 - 09 Apr 2008 21:17
#205338
Here's the turn signal buzzer in oem location on KZ900LTD, which or may not be similar to standard KZ900 model.
This view is taken from right side of bike with forks turned to the straight ahead position.
The buzzer sits inside a rubber fitting behind the brake line connector in front of the vin sticker.
The view in the following post is taken from the right side of the bike with forks turned to full left position.
Good luck! :)
Last edit: 09 Apr 2008 21:17 by Patton.
09 Apr 2008 21:20
#205347
This view is taken from the right side of the bike with forks turned to full left position.
  • davjour
  • davjour's Avatar Topic Author
13 Apr 2008 16:28
#206185
Thanks for the pics! It helps!
  • davjour
14 Apr 2008 13:06
#206447
Thanks for all your responses. I have mine mounted finally. It mounts as I was told on the bottome of the headlight shell. The electrical plug for mine was inside the headlight shell. I only ride my KZ enough to keep it running good. I don't think the buzzer will bother me. My goal is to return my kz900 to original condition.
