1979 kz750 twin coil
  • bigheadkz
  • bigheadkz's Avatar Topic Author
31 Mar 2008 00:01
#203208
Is ther an newer coil like accel or dyna for this bike
  • steell
  • steell's Avatar
Re: 1979 kz750 twin coil
31 Mar 2008 05:15
#203222
Accel bolts right on, holes line up, etc.
I haven't tried a Dyna, so don't know if the same applies.
I cut the primary wires off the old coil and crimped eyelets on the end to fasten them to the Accel coil, that's the only thing I needed to do.
  • bountyhunter
  • bountyhunter's Avatar
31 Mar 2008 09:50
#203259
This place sells the new OEM coils for $55
www.regulatorrectifier.com/catalog/kawas...ion-coil-p-1628.html
  • bigheadkz
31 Mar 2008 11:16
#203280
steel.
what about updating ignitions . 1982 kz750 twin has a different setup
  • steell
  • steell's Avatar
31 Mar 2008 13:07 - 31 Mar 2008 13:07
#203320
The electronic ignition off a KZ440 or the 82-83 750 twin will bolt right on, I know this for a fact, I've used both :)
Last edit: 31 Mar 2008 13:07 by steell.
  • bigheadkz
01 Apr 2008 01:12
#203449
do i have to change the stator or anything for the electronic ignition
  • steell
  • steell's Avatar
01 Apr 2008 04:56
#203456
You have to change the timing advancer and replace the points mounting plate with the ignition pickup (it doesn't use a mounting plate), and mount the igniter somewhere (I mount it to the side of the airbox behind the right sidecover).
I bought a couple of 440 wiring harnesses off eBay to get the plug for the igniter, cut it off and spliced it in the 750 wiring harness.
IIRC there are two plugs on each harness that will work for the igniter.
