tail light wiring
- rsolano
tail light wiring
27 Mar 2008 19:52
Since getting my bike previous owner had a mess of the original tail light housing and light. I want to put a smaller aftermarket light but the original wires to the light are 3 wires- black w stripe a red and a blue one. the aftermarket light has only red and black and i've tried to configure it like the original but can't get it to work. Does anyone know how to wire this correctly without messing any wiring up?
1978KZ1000, stock w exception of aftermarket 4 into 1 and air pods
- Qdude
- It is all good.
Re: tail light wiring
27 Mar 2008 20:40 - 27 Mar 2008 20:41
In your signature on your profile you can put in what type of bike you have. (like the info in gray I have at the bottom of my posts) Then people can be really specific with the advice they give you.
The striped black wire is ground
It should also go to the turn signals
The red is marker
and the blue is brake
Kool?
The red is marker
Kool?
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
Last edit: 27 Mar 2008 20:41 by Qdude.
- Qdude
- It is all good.
27 Mar 2008 20:47 - 27 Mar 2008 20:48
here is the address of the download page from this site that I found useful for my particular bike.
kzrider.com/index.php?option=com_docman&...w&gid=105&Itemid=108
Jump to this page, scroll down and download the file.
It is a color coded wiring schematic for a 77 650 C1.
Cheers
Cheers
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
Last edit: 27 Mar 2008 20:48 by Qdude.
- Qdude
- It is all good.
27 Mar 2008 20:56
Of course the striped black wire is the terminal for both of the other wires, blue and red. It runs and connects to all things ground.
The red wire runs to the ignition switch and gets power when the key is turned.
The blue wire should hook up to the brake lever switches front and back, and the brake light failure indicator light.
If this does not work, then check the obvious fuses, damaged wires and battery power problems. Then start tracing wires back to the sources.
Good luck.
Good luck.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- 79MKII
- Love Them Kaws!
28 Mar 2008 10:04
Your aftermarket tail light may not have a ground wire. If that's the case, it must be grounded through the housing when mounted (is the housing metal??). Then one of your 2 wires should be for tail and the other for brake. There is also a chance that you only have a running light (single filament bulb) and the wires would be ground and tail (no brake function). Coming from your bike you'll have a ground, tail, and brake circuit. Keep us posted.
The Kaw List:
- rsolano
01 Apr 2008 10:43
Thanks for everones input, it helped fix my electrical problem
