Retro Fitting a Newer Rectifier/Reg onto old 1977 KZ750 Twin
  • jtgraha2
  • jtgraha2's Avatar Topic Author
27 Mar 2008 05:49
#202444
Hey,
I'm having a charging issue with my 1977 KZ750 Twin. It won't charge the battery. I believe it's the rectifier thats gone bad. My question is can I take a newer Rectifier/Regulator style with 3 legs (my original dynamo has 3 legs) and simply install it into the system in place of the old one?
Thanks,
Jon
  • steell
  • steell's Avatar
Re: Retro Fitting a Newer Rectifier/Reg onto old 1977 KZ750 Twin
27 Mar 2008 08:43
#202475
Nope, just using the 78-83 regulator won't work.
You will need the 78-83 stator, rotor, engine sidecover, and reg/rec.
And the KZ440 electronic ignition timing advancer, pickup, and igniter, to convert to electronic ignition (or the same parts off a 82-83 750 twin).
  • Qdude
  • Qdude's Avatar
  • It is all good.
27 Mar 2008 20:59
#202600
It is easy to build one from Radio Shack parts.
77 KZ 650 C1.
77 KZ 650 C1.
