Coil Swap ?
  • rdgrnr
  • rdgrnr's Avatar Topic Author
Coil Swap ?
23 Mar 2008 10:18
#201728
Does anyone know if I can use the coils from my 79 1000 on my 77 650? I checked Kawasaki.com, and the parts #'s are different obviously. The other part to the ? is: if I can use them, will the swap make any difference in the spark?
The 79's have accel wires which I would rather have on the 650
Thanks
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Coil Swap ?
23 Mar 2008 11:45 - 23 Mar 2008 11:46
#201747
As long as the '79 1000 had points ignition you can use the coils on your 650, if it has points as well.
The mounting holes on the coils may be different, so you will need to deal with mounting them.
I used later model coils as I switched to a kawi elec. ign.
The mounts were further apart than the 650 stock coils. I mounted one mount/bolt and used a large zip tie in place off the second mount/bolt, on each coil.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 23 Mar 2008 11:46 by rstnick.
