Need bottom mount headlight bracket for 79 KZ650 B
  • elcid
  • elcid's Avatar Topic Author
20 Mar 2008 02:30
#201145
I have a 79 KZ650 B3. Stock came with a giant headlight with side mounts. I would like to install an aftermarket bottom mount headlight. Is there anything that will bolt right on from another make/ model/ year? Or anyone else found a cheap & creative solution for a bottom mount bracket? Thanks.
  • elcid
Re: Need bottom mount headlight bracket for 79 KZ650 B
03 Apr 2008 21:59
#204135
anyone have any ideas? post a photo if so.
  • casper3043
  • casper3043's Avatar
04 Apr 2012 03:27
#513952
i have the same question...anyone have any solutions?
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
04 Apr 2012 07:47
#513962
The best solution I would be able to come up with is to use the mounting setup from a 650 SR or 650 LTD. It is a less noticeable type of bracket being made of chromed steel round stock and does not cover the fork tubes between the upper and lower trees.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • damarble
  • damarble's Avatar
04 Apr 2012 12:53 - 04 Apr 2012 12:56
#514013
I have both of those side mount styles in the garage if you want a comparison shot.
Another good looking side mount option is those ebay brackets for about $15-20. They say for 32-36mm forks but the 36" is a little fat for a perfect fit. I ended up using them and replacing the side bolts with mini stalk blinkers, looks very clean IMO. Too bad the LEDs won't work on the bikes electrical system so I have incandescent ones coming. I personally love the 7" rounds, you can put a fancy Miata lens in it, I got some with a LED halo (which may not actually work if the blinkers are any indicator (pun intended)).
If you must go bottom mount I wouldn't think it would be hard to bend up a little bracket to bolt to the mount for the KAWASAKI chrome bar under the headlight.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
Last edit: 04 Apr 2012 12:56 by damarble.
