Stator grommet wire assembly
  • strider
  • strider's Avatar Topic Author
18 Mar 2008 08:35
#200741
I bought a new stator cable assembly, including the rubber grommet and have not been able to feed the wires with the plastic sheath through those tiny holes. Any trick to this? I would like to stop that perpetual drip, drip, drip!
Also, does it matter which order these yellow wires are fed?
  • Locozuna
  • Locozuna's Avatar
Re: Stator grommet wire assembly
18 Mar 2008 09:43
#200755
I believe the wires go into the grommet on a hard angle if I remember right. (Just did it last year...duh) No there is no order to how the wires go thru the grommet. One word of caution is make sure to use a sealer where the brommet rides and after it's cured seal the wires good. Mine is still leaking even tho I did and it was a new grommet too. I have to re-do it this spring. There was a thread recently about how to do it successfully. Here is a link kzrider.com/index.php?option=com_kunena&...00687&catid=2#200687
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • strider
18 Mar 2008 11:25
#200770
Thanks. We got the wires through. It looked like order didn't matter but we weren't sure. The tri-bond is curing as we speak. Hopefully that does it!
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
19 Mar 2008 08:34
#200937
Please keep me(us) posted on how that 3-bond is working,if ya would.
I'm going to be doing the same thing soon.
Thanks Strider!B)
1977 KZ1000 A-1
