Tach problem on KZ1000
- fordtruck
12 Mar 2008 08:51
The tach on my 77 KZ1000 is flaking out. If I rev the motor in neutral, the tach works fine. Out on the road it will either lag way behind or jump well above the rpm's that I'm actually turning. I've see it jump up to 11,500 rpm while cruising. It doesn't always act this way. Somtimes it will work fine. The tach is cable driven. I glanced at the gears on the cam and tach drive while I was adjusting the valves, and they appeared ok. Is is just my cable going bad or the tach?
'77 KZ1000-MTC 1075 kit. Stage 1 port
- OKC_Kent
Re: Tach problem on KZ1000
12 Mar 2008 10:21
Try lubing the cable and see if it helps any.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- Tony
Author
13 Mar 2008 00:27
I had the same problem. I took my tach apart, cleaned it, put it back together and it worked fine for years after that.
- fordtruck
13 Mar 2008 10:29
How difficult is it to take the tach apart? Are there any online tutorials for it? I took the bike for a short ride yesterday and the take worked good. Maybe the warmer weather helped??
- 76 LTD
17 Mar 2008 03:51
check cable first it could be binding inside the outer cover or one of the square ends could be rounded off.
