Headlight Pulser: What Should It Do?
- bountyhunter
10 Mar 2008 13:19
I am thinking of building a headlight pulser sircuit. Would like some info on what they typically do or should do.
Do you usually pulse the low beam or high beam?
Does it leave the low beam on continuosly and "pulse on" the high beam as well?
What pulse frequency? Halogen sealed beam lights come on kind of slowly so very fast pulsing will not show up, it will look more like steady light. Is three pulses per second about right?
I am thinking of bulding one and I want it to be automatic.... I was thinking of using a solid state pulser in line with the high beam. When I shift to high beam, it would pulse the High beam during the day, just go steady on at night.
I would use a light-sensitive resistor to disable the flasher at night.
- Vter Bob
Re: Headlight Pulser: What Should It Do?
10 Mar 2008 16:59
There is a federal law that mandates how headlight modulators work.
See it here: tinyurl.com/2urmh
They are LEGAL in all 50 states.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- bountyhunter
10 Mar 2008 21:54 - 10 Mar 2008 21:59
Very interesting, one thing I wondered: does pulsing the lamp shorten it's life compared to just letting it run normally?
Last edit: 10 Mar 2008 21:59 by bountyhunter.
- loudhvx
10 Mar 2008 23:11
bountyhunter wrote:
Interesting question. My guess would be it shortens the life because of the cycling temperatures affecting expansion and contraction in the filament material. But it's just a guess.
Just make sure it doesn't flash too deeply or at the right frequency to set off emergency traffic signals. It'd be a shame to always have a green light...
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- robjonrik
13 Mar 2008 17:42
bountyhunter wrote:
It depends on the circuitry. If you pulse 100% voltage to it, yes it shortens the life. If you pulse 80% voltage to it, the life should be close to the constant on hour rating.
- bountyhunter
14 Mar 2008 11:30
robjonrik wrote:
Yeah, problem is pulsing 80% will make the circuitry a lot more complicated. It's very easy to use a power P-FET to pulse the 12V onto the bulb (which is 100%), not so easy if I have to drop voltage in series as that will require a power resistor to dissipate the power.
bountyhunter wrote:Very interesting, one thing I wondered: does pulsing the lamp shorten it's life compared to just letting it run normally?
- loudhvx
14 Mar 2008 13:00
You could use pulse width modulation instead of a dropping resistor. Then just vary the duty cycle to find the amount of reduction you want. The FET would be full on or full off. You'd probably only need 100 hz or so. High frequency modulation shouldn't affect a filament's life as much (as slow cycling like in turn signals), because the filament will remain glowing during the off-time, just not quite as brightly.
1981 KZ550 D1 gpz.
Other links.
Other links.
- bountyhunter
14 Mar 2008 15:42 - 14 Mar 2008 15:59
loudhvx wrote:
I see what you mean. Have a free running osc set at maybe 100 Hz to prevent flicker and adjust the duty cycle of that guy to be fixed 80%. And, use another 555 oscillator (set to about 3 Hz) to power the one running at 100 Hz to get the pulsing mode of the light. That could work.
Last edit: 14 Mar 2008 15:59 by bountyhunter.
