KZ400 Coil problems.
  • Becker
  • Becker's Avatar Topic Author
  • The Doctor Will Rise Again
04 Mar 2008 15:27
#198406
Ok ladies and gentlemen I have a KZ400 that I am restoring and I am trying to figure out what is wrong with the ignition circuit. I replaced the condensor and points timed it out and everything worked fine. I statrted the bike and warmed it up to set the carbs which I just rebuilt and it ran for about 5-6 minutes. Suddenly it shut off, and not like the stuttering shut down of carb problems it was very sudden. So I pulled the plugs to check for spark and ther was nothing. I took out the old multimeter and read 9.6 volts going to the coil (ya I know the coil power mod is the next thing on the list for this I just wanna make sure it works first). I switched to ohms and got only 1.4 ohms across the coil. I never checked this before I started it but isn't supposed to be more like 4 ohms? Nyway if anyone can enlighten me on what is going on that would be great.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • bountyhunter
  • bountyhunter's Avatar
Re: KZ400 Coil problems.
04 Mar 2008 16:56
#198422
Is this the stock coil? If it is, I do think it's hosed.
I have the 750 twin, and probably a similar coil. I think the stock coil resistance should be more like 4 Ohms than 1.4 Ohms. That is the lowest I ever heard of, since it would allow about 10A of current flow through the coil primary when the points close. That would dissipate 140 Watts in the coil and fry it quickly.
Just to help you out, I'll show you a site where they sell NEWreplacement coils for the twins for $49:
www.regulatorrectifier.com/catalog/kawas...ion-coil-p-1628.html
I paid about $30 + shipping for a greasy used one I found on Fleabay because I didn't know about this place selling new ones so cheap.
  • Becker
04 Mar 2008 22:34
#198476
Thanks for the help. I have to agree I think that this one is grenaded but I just bought another one from that website so I'm excited about that. I'll let you know how it all turns out. Thanks again.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
05 Mar 2008 06:41
#198508
1.4 ohms isn't so far off if the bike also ran a ballast resistor. I checked at Kawasaki but the parts diagrams are tough to navigate and seemed incomplete. Do you have a wiring diagram?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Becker
05 Mar 2008 09:16
#198526
KZCSI
I have the wiring diagrams. What should I be looking for that would be a ballast resistor? Better yet what is a ballast resistor?? I already bought a new coil but I would like to know what a ballast resistor is. Thanks for all of your help.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
  • bountyhunter
05 Mar 2008 09:59
#198534
Becker wrote:
KZCSI
A ballast resistor is an external series resitor that was wired in line with some coils once upon a time. It's job was to limit the DC current flow into the coil primary when the points closed. I remember back in 1979 asking the dealer about my 750 twin, and he said Kawi only uses 12V coils (so there would be no external resistor).
If there was one, it would probably be a small block maybe one or two inches long mounted to the frame somewhere. They get very hot so they need heat transfer. If your bike is stock, it won't have one.
Post edited by: bountyhunter, at: 2008/03/05 13:00
