Dyna plug wire crimping..got a pic?
  • old650
  • old650's Avatar Topic Author
03 Mar 2008 12:07
#198166
I have the Dyna ignition/green coils/wires etc. The whole deal. I understand how to set it all up for the most part and have primaries screwed on etc....but. I did not recieve any info on crimping the wires. I assume that I slip on a rubber coil boot, remove insulation to expose some wire, bend the wire over intact insulation, then crimp on brass contacts, slide boot up, install into coil. OK... how far up do I push the wire into the crimp? Up to the secondary crimping past that hole in the back? say 4/5ths up the brass contact? (my guess) Or, just push it 1/4 way in? Dunno, got a pic? As I said, I have no info on this and don't want to queer up the brass contacts by doing it twice. Got a pic of how you did yours? I would rather ask a seemingly silly question and be anal, than mess a job up. Thanks.
Post edited by: old650, at: 2008/03/03 15:10
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Dyna plug wire crimping..got a pic?
03 Mar 2008 14:38
#198187
This should help you Chris.
If you need more pics,just yell.I'll
have the leads off for a while yet...
1977 KZ1000 A-1
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
03 Mar 2008 14:44
#198188
Here's another pic(a bit clearer).
And it sounds like you have the whole procedure correct.
1977 KZ1000 A-1
  • wiredgeorge
  • wiredgeorge's Avatar
04 Mar 2008 06:33
#198308
I like to push the insulated part up into the part that clips into the coil a bit to make it fit a bit more tightly when installed... what Sandy has done will prolly work just fine though.
  • old650
04 Mar 2008 19:19
#198449
Thanks guys, the help is very appreciated. I prefer to clear up every last little question, then go do something right the first time. ;)
