KZ550 No spark
- j_bizach
KZ550 No spark
02 Mar 2008 19:07
Trying to start my 550 last nite the battery died so i threw the charger on this morning she wouldnt start so i checked the spark and no spark. Last night it was sparking fine any ideas.
- Bluemeanie
Re: KZ550 No spark
02 Mar 2008 19:15
Not much would change overnight except battery. Check it for voltage and connections. Also check fuses...
Post edited by: Bluemeanie, at: 2008/03/02 22:15
- KZ250LTD
Last edit: 20 Dec 2011 04:00 by KZ250LTD.
- robjonrik
Re: KZ550 No spark
04 Mar 2008 02:25
j_bizach wrote:
Unfortunately, you might have pulled too much current through your igniter and fried it. I only have kz1000 igniter specs. Get a set of 550 igniter specs and ohm out your igniter.
If your igniter is fried, rather than a $700 igniter, Google HEI KZ and find out how to use a $20 igniter to replace the KZ igniter.
- loudhvx
Re: KZ550 No spark
05 Mar 2008 09:53
robjonrik wrote:
Post edited by: loudhvx, at: 2008/03/05 12:54
www.geocities.com/loudgpz/GPZgmHEImod.htmlIf your igniter is fried, rather than a $700 igniter, Google HEI KZ and find out how to use a $20 igniter to replace the KZ igniter.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
