Starter woes: KZ650
- seanof30306
Starter woes: KZ650
02 Mar 2008 11:03
'79 KZ650 B3
My starter's gone crazy.
Intermittently, it partially engages, then disengages. Real ugly sound when it does it; grinding, clanging, etc.
Reminds me of old Ford starters when the Bendix drive would go out.
I'm guessing it's the starter clutch?
If so, do you have to split the cases to fix it?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- OnkelB
Re: Starter woes: KZ650
02 Mar 2008 12:13
No, it´s actually the other way around, you have to remove the secondary shaft and starter clutch in order to split the cases.
Here´s a link to a write up I did on the subject (pdf):
KZ650/750 four starter clutch repair
It is even possible to do the repair with the engine still in the frame, several members here have done it that way.
Post edited by: OnkelB, at: 2008/03/02 15:15
77 KZ 650 B1, 82 GPz 1100 B2.
- seanof30306
02 Mar 2008 12:26
Man, that is great!
Thank you very much.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- seanof30306
06 Mar 2008 14:08
OK, got her torn down. Here's what I need. On the diagram you put on page 1:
#14 gear is bad.
#10, #11, #12, the spring, roller, and plunger in the starter repair kit.
The one I need is A1.
I looked on Z1Enterprises.com, but don't see them. They also don't show an oil pan gasket.
Can anyone tell me where I can get those parts?
Thanks
#14 gear is bad.
Thanks
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- bountyhunter
06 Mar 2008 15:37
seanof30306 wrote:
These guys probably have a used starter setup.
www.mcmart.com/mall/mc_kawa_part.htm
#14 gear is bad.
Thanks
- steell
06 Mar 2008 20:12
OnkelB wrote:
I don't think so, to remove the crank you do, but not to split the case
Leastways that's the way it is on the 750 four motors, and I'm pretty sure the 650's are the same. The secondary shaft is in the bottom case half, so you have to have the motor right side up and remove the top case, then the crank and secondary shaft remain in the bottom case. If you want to split the case while the motor is upside down, then you have to remove the secondary shaft first.
And Z1 has lots of stuff that's not listed on the web site, and they can get lot's more. It's always worth giving them a call.
Post edited by: steell, at: 2008/03/06 23:23
- OnkelB
07 Mar 2008 04:35steell wrote: The secondary shaft is in the bottom case half, so you have to have the motor right side up and remove the top case, then the crank and secondary shaft remain in the bottom case. If you want to split the case while the motor is upside down, then you have to remove the secondary shaft first.
That´s true, Steve, it can be done that way if the top end is already removed. Guess it´s a matter of preference - imo splitting the cases with the engine upside down is the easiest way as you´ll have to flip the engine over anyway, most of the crankase bolts are on the bottom. It just makes sense to me to remove the topend and top bolts, flip the engine over, remove the bottom bolts and lift the lower case off. Another benefit of the upside down way (with secondary shaft removed) is that you can split the cases without touching the topend in case you only need access to the transmission.
Post edited by: OnkelB, at: 2008/03/07 07:52
- N0NB
- Blue handles better
07 Mar 2008 05:03
Check the prices over at
Ron Ayers Motorsports
and just type the Kaw part number in their search box. If you look at the part that is the "one way assembly", understand that it includes the rollers, pins, and springs.
I did one last year and have documented my experience a few times.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- steell
07 Mar 2008 07:24
OnkelB wrote:
Ahh, that's the difference then
I have done a couple of 750's, but both of those were for 810 and six speed conversions, so the top end was off anyway.
- seanof30306
07 Mar 2008 13:26
N0NB wrote:
Thanks for the lead. I didn't see the "one-way assembly", and the guy hadn't heard of it, so I just ordered 3 of each.
I also found the parts at cheapcycleparts.com, and their prices are a little better, but I kept getting an answering machine when I called them.
Partsnmore.com has a "starter clutch kit" with 3 of each that was 3.00 cheaper, but they have a 35.00 minimum order, and they didn't have the starter sprocket I need, too.
Post edited by: seanof30306, at: 2008/03/07 16:30
Check the prices over at Ron Ayers Motorsports and just type the Kaw part number in their search box. If you look at the part that is the "one way assembly", understand that it includes the rollers, pins, and springs.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
