KZ1100 electrical accessory leads
  • tjhiggin
  • tjhiggin's Avatar Topic Author
27 Feb 2008 16:26
#197264
Where are the electrical accessory leads physically located on a KZ1100? I'm going to use them to power my GPS and can't find them.
Much obliged...
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
  • loudhvx
  • loudhvx's Avatar
Re: KZ1100 electrical accessory leads
27 Feb 2008 20:03
#197300
I can't say for sure on the 1100, but generally, there is a pair of leads buried in the headlight rats-nest, and there should be a pair somewhere near where the seat meets the tank, or possibly near the battery.
  • tjhiggin
28 Feb 2008 11:06
#197386
Thank you. I have looked in both those places with no luck, but will look again.
  • Tommotbird
  • Tommotbird's Avatar
28 Feb 2008 12:11
#197397
I reckon that there should be a black & yellow lead which is pretty near the fuse box & battery. I have an A2 and I will have a look in daylight tomorrow.
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
  • FloridaBiker
  • FloridaBiker's Avatar
28 Feb 2008 17:26
#197434
You will find a black and yellow lead in the headlight.
If that doesn't work for you, splice into the red wire on either coil.
  • robjonrik
  • robjonrik's Avatar
01 Mar 2008 17:17
#197812
WARNING! THE BLACK YELLOW LEAD IS USUALLY THE GROUND ON KAW BIKES..
  • Bluemeanie
  • Bluemeanie's Avatar
01 Mar 2008 19:30
#197833
I'd say check in the headlight again? I've never probed mine for + or - but there is a bunch of empty leads in there. Why did the factory do that?
  • loudhvx
  • loudhvx's Avatar
01 Mar 2008 22:29
#197861
I think it was so one harness would work on models going to different countries. Some countries had the turn signals in different places, etc.
  • tjhiggin
08 Mar 2008 20:54
#199146
Thanks everyone for the help. Today I was able to find the leads under the seat and get the power outlet wired up. The GPS works great on the bike and I confirmed that I'm able to operate it through the clear plastic window of the tank bag.
