1977 KZ750B2 LTD digital ignition?
- DirtySol
26 Feb 2008 21:09
Does anybody know of a digital ignition that is available for the 750 twins?
I am in the process of building a high HP twin for my KZ but I would really like to know of an electronic ignition that is available for it.
I thank anybody with any information that is helpful
- KZ250LTD
Last edit: 20 Dec 2011 03:49 by KZ250LTD.
- loudhvx
Re: 1977 KZ750B2 LTD digital ignition?
26 Feb 2008 22:38
I don't think there is a Dyna for that bike (at least not yet). I believe you can use an electronic ignition from the later 400 or 440 twins. Steell will know more about it. Biquetoast may know of one also. You guys out there?
Also, i seem to recall there may be another brand that made some aftermarket ignition for it... Boyer? or Newtronic?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- bountyhunter
27 Feb 2008 09:39
DirtySol wrote:
Any CDI that is designed to work with points will work on your bike.
Post edited by: bountyhunter, at: 2008/02/27 12:40
On my 1979 KZ750 twin, I added an aftermarket CDI ignition that uses the standard points as the breaker element but boosts the sparking voltage. It also works with the stock coils. It is a lot better than stock ignition, but it isn't computer programmable or anything.Does anybody know of a digital ignition that is available for the 750 twins?
- Shoe48
- Live each day as it is your last
- Shoe48
- Shoe48
