performance ignition 101
- Kingcobra
23 Feb 2008 21:49 #196566
by Kingcobra
performance ignition 101 was created by Kingcobra
ok so I have a 78 KZ650B ... my ignition consists of accel 3 ohm coils, accel 8.8 wires, dyna s ignition, and NGK B7ES plugs with the plug gap set at .035 per accel's instructions. is there anything else I need to change for the best possible performance from my ignition system?
- loudhvx
- Thank you received: 1616
23 Feb 2008 22:35 #196574
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic performance ignition 101
Once it's running, just make sure you have full battery voltage to the coils, and verify the timing with a light to make sure the advance is up to spec. As the advance springs wear, the motor may experience a little knocking if it advances too quickly. Also make sure the advance mechanism is lubed and operating correctly.
1981 KZ550 D1 gpz.
Other links.
