Electrical Geniuses?? (Taillight Integrator)
- bountyhunter
Re: Electrical Geniuses?? (Taillight Integrator)
21 Feb 2008 09:13
79MKII wrote:
Thanks
It may not work with a standard flasher because they require the full current load of two regular lamps (front and rear) to make them flash properly. LED's only use about 1/5 as much current.
Post edited by: bountyhunter, at: 2008/02/21 12:15
It states in the add that it will work with LED's. I don't think he actually said "current" or "voltage", but only called it "% output". Here's the add:
Illuminator Sport
It does say that you need an electronic flasher if used with LEDs though, so I'm not sure what that indicates??<br><br>Post edited by: 79MKII, at: 2008/02/20 20:38
Thanks
- 79MKII
- Love Them Kaws!
21 Feb 2008 09:22
bountyhunter wrote:
That makes sense - the flashers won't work if a bulb is out. I still can't make up my mind if I should go ahead and use this unit or go with the trailer type.:S
Post edited by: 79MKII, at: 2008/02/21 12:23
[It may not work with a standard flasher because they require the full current load of two regular lamps (front and rear) to make them flash properly. LED's only use about 1/5 as much current.<br><br>Post edited by: bountyhunter, at: 2008/02/21 12:15
The Kaw List:
- bountyhunter
21 Feb 2008 09:26
79MKII wrote:
The standard flasher is just a relay with a bi-metallic strip inside. Two different (very thin) metals sandwiched together to make the strip that makes contact to let current go to the light. As the current flows into the strip, the metal heats up: one is designed to contract and the other expands so it forces the piece to "curl" which breaks the connection. As it cools, it returns to original shape and keeps cycling until the current stops.
If there isn't sufficient current, the strip doesn't get hot enough to move and it never flashes.
Post edited by: bountyhunter, at: 2008/02/21 12:27
bountyhunter wrote:[It may not work with a standard flasher because they require the full current load of two regular lamps (front and rear) to make them flash properly. LED's only use about 1/5 as much current.<br><br>Post edited by: bountyhunter, at: 2008/02/21 12:15
- FloridaBiker
22 Feb 2008 19:45
On the custom bikes I build for customers I always use LED's exclusively.
I find the $10 electronic flasher(ADVANCE, AUTOZONE, etc)as above does the job perfectly.
And it plugs in to the existing location.
Simple and reliable.
- bountyhunter
29 Feb 2008 10:56
FYI: I finally got around to building up and installing the solid state tail light converter that allows both rear turn signals to work as stop lights and still work as turn signals.
Unlike the $15 converters, the rear signals don't "flip polarity" with the brake light on. The front and rear blink in unison regardless of whether the brake light is applied.
The circuit is somewhat more complicated, EE geeks would have no problem but it might not be worth the trouble if you aren't used to building things up from scratch.
PDF file is available to anybody who wants the schematic.
- 79MKII
- Love Them Kaws!
29 Feb 2008 11:22
I'll send my email by PM. I'd like to have a copy. Still don't know if I should use the trailer converter or the illuminator sport. I hadn't thought of the turn signals flipping the way they do - I wouldn't like that on a motorcycle (I don't have a rational reason why, I just don't like the idea).
Maybe your schematic holds the answer. I'm thinking it would work as a taillight integrator too, right? I should be able to use my dual taillights as tail/brake/turn and remove my turn signals, right?
The Kaw List:
- loudhvx
29 Feb 2008 11:27
bountyhunter wrote:
Alright, I admit I'm interested. Can you post a link? If you need a place to host it, I can put it in my file storage and put a link to it.
EE geeks
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- bountyhunter
29 Feb 2008 13:39
loudhvx wrote:
I'm pretty much brain dead on working PC's, it would be easier if you all send me a PM so I can email it to you.
If somebody knows how to link it up and post it, that would be OK with me.
bountyhunter wrote:EE geeks
- bountyhunter
29 Feb 2008 13:41
79MKII wrote:
My reason is I don't want to give the cops any reason to write me a fix it ticket. That wierd double flicker that could happen if you are tapping the brakes with the turn signal on would do it.
- bountyhunter
29 Feb 2008 14:34
loudhvx wrote:
I just sent the schematics of the converter and the solid state flasher I use with it to 79MkII.
Hopefully, he can do the magic to post it where everybody can get it.
If not, I can email it to you.
- rstnick
29 Feb 2008 15:02
I'd like to see that. I decided not to give up turn signals. I like the idea of the turn signals coming on with the brake light, but still work independantly as turn signals.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
29 Feb 2008 15:38
Hey I got the washer for sale for a Turn Signal integrator for sale on ebay here:
ebay fun
Check it out.
ebay fun
Check it out.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
