Electrical Geniuses?? (Taillight Integrator)
- 79MKII
- Love Them Kaws!
18 Feb 2008 10:58
I felt like wasting $99 and bought a taillight integrator for my dual-bulb taillight. I received the unit and these instructions:
i148.photobucket.com/albums/s16/79MKII/M.../IllSportDiagram.jpg
WTF? How can this work if the wires for the running lights and brake lights are wired together? Does this thing actually have a variable output of some sort that will vary the bulb brightness? Both filaments would have to be lighted if connected as shown :S :blink:
I don't get it...
I don't get it...
The Kaw List:
- StreetfighterKz
Re: Electrical Geniuses?? (Taillight Integrator)
18 Feb 2008 11:16
You spent $99 on the intergrator? Lockhart Phillips sells their's for $49 and comes with better instructions.
I think what they're saying is to twist the two running light wires together and the two brake light wires together on the main harness side then connect those to the box. Coming out of the box they'll be seperate again.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 79MKII
- Love Them Kaws!
18 Feb 2008 11:31
StreetfighterKz wrote:
Gee, thanks!
The diagram actually shows the wires from the Bulbs being twisted together. They suggest that you shrink wrap the LH running and brake wires and only use the RH wires for connecting to the box. The input makes sense to me, but there should (has to be?) a separate output for each filament, right??
Later, Doug
Gee, thanks!
The Kaw List:
- StreetfighterKz
18 Feb 2008 12:05
The way I wired mine in was...
Running light (IN) 2 into 1
Brake light (IN) 2 into 1
Left TS (IN) 1 into 1
Right TS (IN) 1 into 1
Right Running light (OUT) 1 into 1
Left Running light (OUT) 1 into 1
Right Brake/TS (OUT) 1 into 1
Left Brake/TS (OUT) 1 into 1
I hope that makes sense. (It did in my head but that doesn't mean anything. :silly: )
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- loudhvx
18 Feb 2008 12:27
Geez 79MK, no offense, but the instructions on that thing are hard to read. It's legible, but not readable. All caps? :blink:
Yes, it's strange that you tie both filaments together. Theoretically it'll work if they control the current to the bulb to reduce the brightness for running then increase it for signal/brake (as you suggested). It's possible they did it that way in case you were to use rear bulbs with only one filament. This would allow people to use simple one-wire turn signals as brake/running/signal lights. That would also expain the extra expense. But really, they just need a better set of instructions with a better picture.
Post edited by: loudhvx, at: 2008/02/18 15:28
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- 79MKII
- Love Them Kaws!
18 Feb 2008 12:33
Now that makes sense! That isn't how they show it though:blink:
The Kaw List:
- 79MKII
- Love Them Kaws!
18 Feb 2008 12:35
loudhvx wrote:
No offense taken - that's their mess, not mine!
I agree, those instructions are horrible! They are not written well at all. I had first guessed a translation problem but then realized they are made in the U.S.! I have emailed them and ask for some clarification. I'll let you know...
The Kaw List:
- bountyhunter
19 Feb 2008 10:13
79MKII wrote:
And written by graduates of our public school system.....
loudhvx wrote:Geez 79MK, no offense, but the instructions on that thing are hard to read. It's legible, but not readable. All caps? :blink:
No offense taken - that's their mess, not mine!I agree, those instructions are horrible! They are not written well at all. I had first guessed a translation problem but then realized they are made in the U.S.!
- loudhvx
19 Feb 2008 10:15
bountyhunter wrote:
Aw... come on, we can't assume they gradiated. :laugh:79MKII wrote:loudhvx wrote:Geez 79MK, no offense, but the instructions on that thing are hard to read. It's legible, but not readable. All caps? :blink:
1981 KZ550 D1 gpz.
Other links.
Other links.
- bountyhunter
19 Feb 2008 10:16
79MKII wrote:
The text is gibberish, but the diagram clearly shows only two power feed wires to the rear of the bike. That would imply that the rear lights (running and turn signal) are wired together as one filament. It would be very easy for a solid-state converter circuit to light it as a brake light and also be able to switch it on and off in response to the turn signal flasher signal.
I don't get it...
- bountyhunter
19 Feb 2008 10:17
loudhvx wrote:
That's true.
bountyhunter wrote:Aw... come on, we can't assume they gradiated. :laugh:79MKII wrote:loudhvx wrote:Geez 79MK, no offense, but the instructions on that thing are hard to read. It's legible, but not readable. All caps? :blink:
That's true.
- 79MKII
- Love Them Kaws!
19 Feb 2008 12:33
bountyhunter wrote:
The only problem with that is that it has to work as a tail light too. The bulb needs 3 functions: Running, brake and turn. It would have to vary the brightness too, not just turn it on and off, right??
79MKII wrote:I felt like wasting $99 and bought a taillight integrator for my dual-bulb taillight. I received the unit and these instructions:
I don't get it...
The Kaw List:
