current question
- phil
current question
16 Feb 2008 15:25
sorry , not a kawasaki question but my co-worker drives a 1982 honda nighthawk 750 and was wondering how many amps should it be drawing when running. his has blown 2 regulators and is trying to find out what is causing his problem.
- loudhvx
Re: current question
16 Feb 2008 18:33
Generally speaking, the bike as a whole will take somewhere around 10 amps, maybe up to 15 amps. Honda regulators are the worst I've dealt with, and their alternators aren't good either. I find the most problematic ones are from the early 1980's CB's. Especially the ones using electromagnetic rotors with brushes.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- phil
- trippivot
19 Feb 2008 09:29
those years of cb750 900 1000
79~1983 are prone to electrical problems
it is a emf type of charging system. or excited field
the regulator is not the problem!!
and probably never "blew the reg" to begin with
#1)what is the resistance between the slip rings on the rotor? Insulation Breakdown test?
#2) bare wire on the brush holders grounding out
#3)condition of battery? to have a active field it must load test strong.
#4) how long are the brushes?
there are other tests to isolate the problem.
don't throw any more parts at it until you properly diagnose the condition of the system as a whole.
- BSKZ650
19 Feb 2008 12:59
I have found the same thing as Lou, if you search around you will find a aftermarket improved version, went through this on a friends shadow,
77 ltd1000, current rider
76 kz900, just waiting
- phil
20 Feb 2008 01:43
thanks for the info. i will relay this to my co-worker.
