one wire or two?
  • rdgrnr
  • rdgrnr's Avatar Topic Author
one wire or two?
10 Feb 2008 10:57
#193804
Can I use two wire rear signals in place of the one wire w/seperate ground at the stem?
I am currently using the one wire signals from my 79 1000 on my 77 650. I am replacing those signals with new ones as the old ones are pitted.
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
Re: one wire or two?
10 Feb 2008 12:03
#193814
Could check to see if the 2-wire turn signal uses a dual-filament bulb (one wire for running light and the other wire for blinking), which would also have a separate third ground wire.
Am guessing the 2-wire turn signal may function similar to a taillight-brakelight which also uses 2 wires to the bulb and a third to ground. :)
(But I guess wrong a lot.) :ohmy:
  • rdgrnr
10 Feb 2008 12:10
#193815
Never thought about it that way. I guess I didn't pay attention to the bulb style when I them apart last fall. I'll check them out once it warms up around here.
It's warmed up to minus 6:pinch:
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
10 Feb 2008 14:21
#193830
Yes you can use two wire rear signals in place of the one wire w/seperate ground.
With newer signals that have two wires, one is power & one is ground.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rdgrnr
10 Feb 2008 18:00
#193866
Thanks,
I was hoping to hear that as I don't much care for the one wire style.
Just thinking that the ones from my 1000 might not be stock....:huh:
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
