LED TAIL LIGHTS
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: LED TAIL LIGHTS
11 Feb 2008 16:08
#194040
Jay_G wrote:
I was Refering to the luxeon LEDs
Yeah, me too. I bought the Luxeon 3W LEDs, and I put them into standard sockets (mind you, they are controlled by a Reese trailer kit) in after-market bullet-style dual-filament tail/turn lights, and they work fine.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • bountyhunter
  • bountyhunter's Avatar
Re: LED TAIL LIGHTS
11 Feb 2008 16:45
#194050
Jay_G wrote:
defiately need to heat sink them, i had 4 of them i used to make a custom brake light and didnt heat sink them, just glued them into the fibreglass seat unit, burnt out 3 of the 4 within 4 rides,
you also need to run resistors to them as they wont run 12v.
Then you are describing a different product. The bulb replacement Luxeons come mounted to an aluminum heatsink, have the dropping resistors built in, and screw directly into a 12V socket for a standard 1157 bulb. Nothing else is required, they are simply drop in (or, screw in) but they replace the bulbs as is.
View them here:
www.superbrightleds.com/specs/115x-xLX3.htm
Post edited by: bountyhunter, at: 2008/02/11 19:48
