where do you buy instrument light bulbs from??
- fixer5000
21 Jan 2006 15:40
i looked for either t51's or 12 volt 3.4 watt bulbs for about an hour today on the net and didnt find a one...any ideas???
1978 kz650b pretty much stock
massachusetts
massachusetts
- ejshotgun
Re: where do you buy instrument light bulbs from??
21 Jan 2006 15:47
Don't know for sure what your bike uses but I got mine at Auto Zone....
EiKO(brand name) 53, their listed as 12volt instrument auto bulbs.
- guitargeek
21 Jan 2006 21:11
I plan to switch to LEDs as soon as I run out of my little stash of incandescent bulbs...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- sakiguy
22 Jan 2006 02:19
I got some at Kragen. About 2.50 a pair....pretty expensive.
1983 KZ750 N2 Shaft
- Mcdroid
- Gone Kwackers
22 Jan 2006 03:44
fixer5000:
I assume you are talking about those little glass bulbs with the pinched glass base? The ones that just push into a socket? If so, pull one, take it to any autoparts retail chain store, get the number off it, and there is a new replacement bulb manufactured that will supercede it (those #'s will be listed on the package). I just picked up a set of 10 bulbs (my instrument pod take 9 bulbs) at O-Reilly's.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- fixer5000
24 Jan 2006 15:22
ejshotgun wrote:
are the 53's bright enough? theyre only 2 watts
massachusetts
massachusetts
- inline79
28 Jan 2006 09:15
I've put 53's in my instrument cluster next to original stock bulbs. I find them to be bright enough. I'm not sure if I need super bright instrument lighting ever. At 60 cents a pop, you can always swap them out for something else later.
- fixer5000
28 Jan 2006 15:18
well i got three different bulbs to experiment with. ill let you all know how they work in the spring...thanks for the help and info...steve
massachusetts
massachusetts
- fixer5000
28 Jan 2006 15:18
massachusetts
massachusetts
- johnny chop
28 Jan 2006 15:59
Just picked up some from Pep Boys.#53 They were $2.99 for a pair......
