can i use a 78' 650sr wiring harness on a 78' kz650b2?
  • justed
  • justed's Avatar Topic Author
18 Jan 2008 07:37
#189899
c'mon all you electrical guru's. can you help an electrically challenged person out and save me the horror of making my own harness?!
thanks
:S
Post edited by: justed, at: 2008/01/18 10:40
  • POPTOP
  • POPTOP's Avatar
Re: can i use a 78' 650sr wiring harness on a 78' kz650b2?
18 Jan 2008 08:08
#189905
The Part numbers for the wiring harness for the 78 b2
and the 78 sr are not the same, so they are not identical. They are, however, very similar, and would probably work without much modification.
18 Jan 2008 08:15
#189907
Yep -- a pretty horrible prospect all right.
As already known, among other chassis differences, the B2 has a duck tail whereas the SR does not, and according to Kawasaki.com the two models do not share the same main wiring harness.
Concurring with POPTOP, would guess the two harnesses are basically the same, including matching connectors and color codes, but with a few different length wires serving the same purpose. For example, wiring to the brake/tail light might be longer or shorter depending on the model. Further guessing that the "longer" wires would fit okay, but that the few "shorter" wires, if any, may require an in-line extension.
Others here being far better informed will know for sure.
And almost afraid to ask -- what's wrong with the existing harmess? :lol: [Oops, just noticed the avatar which may answer the question.]
Good Luck! :)
Post edited by: Patton, at: 2008/01/18 11:18
  • justed
19 Jan 2008 01:14
#190039
heh, the avatar is another project. i re-aquired this bike, the kz, after 10 years from the dude i sold it to. he let it sit, butchered the wiring and never even registered it! 10 years later i bump into him and buy it back and it only has 10 miles more than the last time i saw her. guess it's first bike love.:blush:
thanks much for the info, you guys rock.
ed
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
19 Jan 2008 03:57
#190043
A couple of differences come to mind. One would be the SR will have a a pig tail for the fuel sensor where the B does not. Also on the early B models they did not have 4 way flashers where the SR did. I'm not 100% on the 78 650 B's not having them but I know the 77's didn't however the 79 I have does. I also don't remember if the 78 models had the on and off switch still for the headlamp. None of this stuff should stop it from working though, most of the really important stuff will be the same. If you can find a good unmolested harness from an SR I'd have to say that would be better than having to re-make your own harness.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • OKC_Kent
  • OKC_Kent's Avatar
19 Jan 2008 06:13
#190047
tinyurl.com/27xfsv
The link above gets you some wiring diagrams in color.
I see a fuel sensor and a warning light self-checker on the D1, not on the B2, as Gringo said. Both models have headlight on-off switches and Hazards.
Post edited by: OKC_Kent, at: 2008/01/19 09:20
Cashion, OK
78 KZ650 B2 85,000+ miles
19 Jan 2008 15:01
#190123
Very interesting. The '77 KZ650B1 doesn't have the "hazard" switch but the '77 KZ650C1 does. According to the wiring diagrams the '78 KZ650B2 and later versions do have the switch. I didn't know I got this futuristic feature when I bought my C1 in April, 1977. I learn something everyday on this site. Ed
  • fixer5000
  • fixer5000's Avatar
20 Jan 2008 12:52
#190252
for the record my 78 b2 does have the 4 way flashers
1978 kz650b pretty much stock
massachusetts
