spark problem
  • jordan
  • jordan's Avatar Topic Author
spark problem
17 Jan 2008 20:48
#189857
Not kz related, but still motor related. I have recently just rebuilt an ATC 200s. Never had it running before because I just picked it up from an old farmer. Compression was very low, so I rebuilt it first. Now that I got the motor back in, i plugget the 4 wires from the motor into the wiring harness. 2 of these go from the ignitoin to the wiring harness. Even with a new plug, I can only get a spark about every 5th pull, or sometimes not at all. Pretty sure the problem is not the wire, used one from a kz1000, and had the same problem. I believe it is prolly the ignition. The magnet deal attached to the end of the cam turns with every pull. Does anybody have any idea of what the problem could possibly be? Coil? Wire? Ignition?
Post edited by: jordan, at: 2008/01/17 23:50
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: spark problem
17 Jan 2008 22:20
#189862
It's not that certain that you will see every spark. When I'm trouble shooting an engine If I see a spark, any spark, I go on to the next suspected problem.
kzcsi
Post edited by: KZCSI, at: 2008/01/18 01:22
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • trippivot
  • trippivot's Avatar
Re: spark problem
23 Jan 2008 10:03
#190652
it is a self excited type of ignition. it needs quick sharp movement to get a hot blue spark.
those are very sensitive to the air gap on the cam and source coil .010~.015.
next is the cdi box resistance any variance of 10% equals a terminal misfire == new box. I used to have the spec.. 650 ohm maybe?? no Insulation Breakdown.
clean up all connections and get the carb close.
quick start fluid to ease the pull start toil
maybe everything is just fine.
  • Saki Jockey
  • Saki Jockey's Avatar
Re: spark problem
23 Jan 2008 17:05
#190709
Look for good clean ground on coil first.
The ignition systems on the few (dozen) Honda's i've owned have been really bulletproof. If there was a failure here I'd suspect it was in the coil. Tell us, the coil wire was removeable? It wasn't originally 'potted' into place? It's rare for Honda to have a readily replaceable coil wire. What about the coil wire cap, have you eliminated this as well? What about spark quality? Big fat blue or wimpy yellow?
We'll assume you've tried another plug? For the sake of curiosity, what brand are you using?
Rob A.
550 A4
GTA,
Ontario, Canada
