sparx battery eliminator any ever use one
- odl666
16 Jan 2008 15:46
has any one ever used one of those sparx battery eliminator? any problems? thanks
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
1979 gs750e
- 76 LTD
Re: sparx battery eliminator any ever use one
19 Jan 2008 06:26
Had one on an old Triumph and it worked good.But anything is an improvement on the Lucas system.Lucas electric also builds refrigerators thats why people in europe drink hot beer.
- odl666
19 Jan 2008 09:15
Ive done some reading and found out a lot of people have put them on their brit bikes. I guess your wiring just has to be flawless for them to work good. thanks for the reply
1979 gs750e
1979 gs750e
- bountyhunter
21 Jan 2008 13:37
76 LTD wrote:
His prowess with auto electrics is why every Brit refers to Lucas as "the Prince of darkness".
- loudhvx
22 Jan 2008 17:48
The battery eliminator is just a capacitor. Regarding KZ's, some can and some can't use the eliminator. If your alternator uses a big permanent magnet flywheel, then it is eligible for the eliminator.
If the alternator uses a field coil, then it will need some sort of battery, however it can be just a small scooter battery.
The majority of KZ's have permanent magnet alternators. The most notable exceptions are the early (if not all)KZ400's and the 1977 KZ650.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Gra
25 Jan 2010 02:18
Do you need to still have a rectifier / regulator if you have a battery eliminator??
1979 KZ650 - Under restoration
- loudhvx
25 Jan 2010 09:48 - 25 Jan 2010 09:49
Gra wrote:
Also if you do this, and the reg/rec has a brown wire to it, the brown wire must be hardwired to the capacitor. Normally the brown wire gets shut off when the bike is shut off. But that means the alternator is still running un-regulated until the motor actually comes to a stop. This means the alternator is putting out full power during the time the motor is turning and the bike is shut off. (This can happen anytime you are coasting in gear with the ignition off, but it also happens when you turn the motor off for a brief moment.) With a battery, this is not really an issue since a battery can act as a crude regulator. A capcitor does not. It will just get huge surge of voltage until it fails.
To prevent that, the brown wire must be hard wired to the capacitor.
There is no issue if the reg/rec does not have the brown wire and only has the positive-output and ground. I don't think the 79 650 has the brown wire.
Yes, otherwise you will get too much voltage to the capacitor (which is what a usual battery eliminator is.)Do you need to still have a rectifier / regulator if you have a battery eliminator??
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 25 Jan 2010 09:49 by loudhvx.
25 Jan 2010 10:35
76 LTD wrote:
Lucas - because gentlemen shouldn't be motoring about after dark anyway.
