1300 voyager speedometer
  • jjdwoodman
  • jjdwoodman's Avatar Topic Author
  • Live free, or die.
11 Jan 2008 15:46
#188758
When I put the front end back together after the spill, I went for a 40 mile test drive and everything worked, but a week later I took off again and no speedo. It's electronic with a speed sensor driven by the front wheel, and wired back to one of the computers, I guess.
Does anyone know how to test the speed sensor? I don't know if I put something together out of spec or if it's just a coincidence...:unsure:
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • Skyman
  • Skyman's Avatar
Re: 1300 voyager speedometer
11 Jan 2008 17:00
#188763
Do you have a factory service manual? I would imagine that if there is a way to test it, they would tell you there.
West Linn, OR
  • jjdwoodman
11 Jan 2008 20:31
#188796
I have one for the 1200 on pdf. The electrical seems right, but no specifics on testing the unit. I don't know if this one is a hall effect sensor, small generator, or something totally different.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
12 Jan 2008 09:01
#188853
I have a factory service manual in PDF. it's nearly 90 megs however. Wonder if I could email it?
there's a very well documented process for diagnosing the speedometer.
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • jjdwoodman
12 Jan 2008 09:06
#188854
If it's too big, I wonder if it can be broken into sections? I downloaded mine a chapter at a time.
jjdwoodman@yahoo.com
Thanks KZCSI, seem like your always coming to my aid.:lol:
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
12 Jan 2008 09:15
#188855
Here's the drill:
GO to www.cascaderangeriders.org/KawaSixesFiles/
The user name is "KawaSixes" I will PM the password to any one interested. Some how I worry that to post username and password in the same post would invite problems.
Log in and you will find all my Kawasixes files which you can download at your leisure. Unfortunately there can only be one user with the same name at a time so you may have to be patient.
JJ, I sent you the password already.
Good Luck
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
12 Jan 2008 09:20
#188857
Sorry, The name of the file is ZN1300SMS.pdf
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • jjdwoodman
12 Jan 2008 13:05
#188886
Thank you VERY much! That's a whole lot more info than what I had!
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • jjdwoodman
12 Jan 2008 14:02
#188896
Now if only there was a fix for operator error! The wire was pinched at the steering head!:S That explains the 0.L reading... Thanks again, guys.:cheer:
77 650b
81 550 Mostly there
83 ZN1300 Voyager
