Fuse block maintenance tip
- robjonrik
10 Jan 2008 04:44
It should be a part of your annual maintenance/startup program to:
1. remove the fuses
2. using a scotch-brite pad, clean the fuse ends and the fuse clips
3. using a pair of needle nose pliers, gently squeeze the fuse clips together
4. reinstall the fuses
This eliminates a significant number of electrical problems, especially if you have a six wire regulator.
1. remove the fuses
- mariozappa
Re: Fuse block maintenance tip
10 Jan 2008 05:36
OR......
Replace the fuse block entirely with spade fuses and never have to worry about it again!
:whistle:
:whistle:
1977 KZ650C1
and the KZ650/KZ750 Conversion
- JR
10 Jan 2008 17:25
mariozappa wrote:
Yup
Done that also last Fall. No more fuse worries. :whistle: :whistle:
OR......
:whistle:
Yup
- Aric
10 Jan 2008 18:25
Never thought about spade fuses. Can you pick up a block for those at your local auto store?
- JR
10 Jan 2008 18:38
www.centechwire.com/catalog/panels/fb4.shtml
I used something a little bit different but this one should do
- Bluemeanie
10 Jan 2008 18:52
- Biquetoast
- King Jeremy The Wicked
10 Jan 2008 19:24
Bluemeanine and JR - that's the same fuse block I have on all my bikes. It is perfect! And I got it for about two bucks less at WiringProducts.com....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
